Originally posted by: alcalde
Thanks. I believe there are also BIOS issues with this motherboard (Gigabye GA-K8N Ultra-9), it won't post with a new tuner card that works fine in a test system, and I've now managed to make the board un-postable via attempted BIOS upgrade even with a dual BIOS board! This motherboard is SO RMA.
I have a Gigabyte GA-K8NS Ultra-939 with an X2 and I've never had a problem (other than XP issues that microsoft addressed with a Hotfix). Here are my suggestions:
Your Mobo
1) You should have dual-bios (gigabyte speciality), restore your old bios (see the manual)
2) What bios do you have? (should be labelled on the cmos chip) Check the gigabyte site, to see if that revision supports X2. If not, upgrade the bios. Make sure that you remove any devices that you are having problems with first (ie the Tuner card)
X2 and WinXP-Pro
1) Install XP-Pro normally.
2) Install the AMD X2 driver (see AMD site)
3) Install SP2 + all available updates
4) Install MS Dual-Core hotfix and add the registry key (see thread in CPU forum)
5) Install other drivers and apps.
6) Done
The Tuner Card
1) Try different PCI slots. The card may be conflicting with another device (IRQ address, etc...)
2) Make sure the card works with XP and that the drivers are current.
Good luck
