yes dude. they are that much faster. and raid-5 blows. it's not safe for reliable data on cheap drives. hell i had two drives fail the other day. reading the serial to hp for a next day replacement and a 2nd drive amber-light in front of me. raid-10 FTW
Your network is the pipe that you're running data back and forth through.
Is your network faster than gigabit?
you must have had really shitty drives then. never had a samsung fail on me in any raid configuration.
I'm sure too low is the answer. Really, anything not in the hundreds is too low, and even then, he would only just be reaching a significant sample size, except for drives that have a high failure rate (Segate 7200.12 now, IBM 75GXP of ages past). I've had three Samsungs fail, one in a RAID, one still within the RMA period. They must be terrible drives.What is the sample size out of curiosity?
I use GB ethernet/wireless. Router is Cisco e2000. Snynology 411j Seems extremely slow compared to regular HDD in a system but overall very happy - just want more speed and one more drive won't hurt either.
The DS1511+ is supposed to be even faster using link aggregation. 190MB/s read, 160MB/s write.
The Hitachi drives are supposed to be fast, and hot and loud.
Zebo, how are the F4 drives doing? I'm waiting for my DS411+ to arrive. I bought 2x 2TB F4s. I'm hoping there aren't any issues and they don't need to be patched. Unfortunately the compatibility list for 2TB drives is short and most seem to have issues or are loud/hot or expensive.
Keep in mind that gigabit ethernet is only 1000 bits per second. Since there are 8 bits in a byte, you're looking at 125 MB/s theoretical maximum, and your actual throughput will be significantly lower (probably in the 50-60 MB/s range). Wireless is, of course, much slower. I believe a good wireless N connection can reach something like 200-300 Mb/s (~20-37.5 MB/s) - less than 1/3rd of the throughput of gigabit ethernet.
7200 RPM drives may help, but do not expect a night and day difference. I'd personally stick with 5400 RPM drives unless the price difference is negligible or every last ounce of performance really counts. I wouldn't expect modern 5400 RPM drives with high platter density to be your bottleneck.
Based on what you and Cerb are saying it might be best just to stick with what I got for now because throughput won't improve much if at all. Someday soon I will have to build a DIY NAS with 10-15 disks if this one keeps filling up. OTOH I like the 1511+ because you can add modules to it up to 15 disks...plus in general the synology software is outstanding.
Hey ace I forgot to mention when you get F4s apply the patch
http://www.samsung.com/global/busine...bbs_msg_id=386
Yeah - if all clients were connected via cable I see where you're coming from. I should have got the 1511+ and will or build equivalent next time. 411+ was a good move. You bought right, I'll buy twice. See sig.
Raid 5 is better than no RAID and two disks failing at once is like winning lotto.
Do the SATA ports on Zacate mini-ITX mobos support RAID out of the box? Or would one have to get a RAID controller card?right now, zacate is looking very sexy for a nas box. just slap 1gb ddr3 in there and its good to go. uses minimal power, four-five sata3 ports, and pci-e 4x slot for cheap pcie 1x sata controller, or optionally, a nicer 4x controller.
I was hoping someone would come along and make an SLC drive manage the ECC (Raid-3 like) for mechanical drives. since 600gb SAS 2.5" are now mainstream this would rock imo. wish i had the time to hypothetically try that. or use a pair of ssd's for tiered storage cache of a disk set (not far off from flash back write cache).
raid-10 reads from all drives (we are talking about raid-1 pairs striped raid-0 yes?)
For a protected environment with the same amount of disks, yep.it has the best read&write speed for a protected environment.
