What motherboards offer more than 1.85 volts for an XP?
MetroRider
433
do you mean by default settings for more than 1.85v allowed?
if i am not mistaken, can't you mod the Abit line of mobos (i.e. KG7, KR7a) to give you more juice than 1.85, for IIRC, i recall seeing people having volts of 2.0 and greater for their XP's.
someone please correct me if i am wrong.
Metalloid
3,064
Yes some boards can be modded to give you vcore over 2.0
Is the only danger of upping the voltage the added heat, or is there other things that can cause damage?
SnowPunk98
Banned
Jun 15, 2001
4,933
you can do the Vcore mod on the Epox 8KHA+ or 8K7A I think is the one. Or you can wait for the KT333 from EPox which allows up to 2.2vcore with no mods
