What Motherboard Should I get.Please Help.
nickle211
So far I have got a venice athlon 64 3500+ pro.Now I need a motherboard.I already bought 2 and neither worked,I couldnt get them configured or something.Anyway I need a socket 939 motherboard that has the features but is ready right out the box.I dont know how to configure anything so please some suggestions.A good motherboard for a 3500+athlon 64 that will load windows with ease.
o1die
4,785
Please list the "failed" boards, and the rest of your system specs such as memory brand, power supply info, etc. Did you try a format and fresh install of windows, or just boot up to your old windows setup?
evilharp
426
Sorry nickle211, no motherboard is "ready right out the box". You will always need to set things up using the BIOS before you can install your OS.
What was wrong with the previous boards? What brands/models were they?
