What motherboard do i have?! PLEASE HELP!
RollWave
4,201
I have a compaq 8000z/CMT 8QSXE1 with a xp1900 processor (palomino) and I was wondering if there is a way to find out what kind of mobo I have...I dont have a clue...The reason is I want to put in some pc2700 or higher ram! SOMEONE PLEASE HELP! This ram sucks right now!
KF
1,371
If you are looking for what memory it accepts, Crucial has a memory selector.
Their page is :
Crucial memory
Is this what you have?
Upgrades for the Compaq Presario 8000Z Series.
From what I am told, big manufacturers have custom designed mobos, and a proprietary BIOS (with no overclocking available), so info about the mobo is going to have to come from Compaq. Other than that, it looks as if the CPU is 133MHz front side bus, which goes with PC2100 RAM.
Digitl
Banned
Jun 11, 2003
32
www.compaq.com?
cmdrdredd
27,052
357
www.compaq.com?
every thread seems to be filled with digitl's genious
Compaq doesn't tell you what mobo they have in their systems they may tell you specs, but they won't say "we use Asus P4P800 DX" or anything. Common sense. My guess is it's proprietary like Dell. Best bet is to check crucial for a memory selector. Whatever memory crucial recommends (PC2100 or PC2700) you can use.
tcsenter
18,936
568
You could install PC9700 and it will still only run at PC2100 (133MHz) BUS speeds - the same frequency as your processor. There will be no benefit. I suspect the board would accept PC2700 alright, but I would be sure to use the latest ROM/BIOS.
