Do you have a P3 800 already? If you're planning on buying one then get the FCPGA model. If you plan on overclocking i'd suggest you look into the P3 700e. You can get one pretested to 933mhz for $190 @ PCNut - that's about the same amount you'll pay for a retail P3 800eb.
a whole bunch of them are inflicted with a "voltage bug" which prevents them from posting at anything higher than your default voltage (1.65v)
an 800 cC0 should hit 8*133 pretty easily. That's just under 1100 MHz. That's damn fast.
BX is performance king, and I must say this MSI BX Master has been a paragon of stability. I'd go for the BX Master. It just totally kicks ass. MSI rules the mobo world right now, far as I'm concerned.
I'm sure Asus has already addressed the voltage bug in their newer boards. Buying a BX board now doesn't make much sense(although the BXMaster is a killer board). It may still be the performance king but BX is dead and the 815 boards are more hassle free when it comes to overclocking due to the 1/2 agp divider.
