What microSD card for best random write speed?
FreshJR
46
I will be installing android onto a microsd, and so I need good access times rather then throughput.
I understand that class 4 SD cards typically have WAY better random write speeds then class 6 or 10 SD cards. A select some of the class 10 SD cards have BOTH.
I want the cheapest SD that will have good random access. Has anyone done the research before?
I found that this Sandisk 32GB class 4 has 1 MB/s random access as compared to an average of .008 MB/s. This is a big difference, :eek: so I want to make sure I buy the correct one.
The thing is, I dont need that much space for this application, and the 16GB is $10 cheaper, but I couldn't find any info on the 16GB sandisk. I dont want to get stuck with a junker.
http://www.amazon.com/gp/product/B00...60_cs_sce_dp_5
EDIT: While 16gb benchmark is on there too, that model number matches up the 32GB. :confused:
