What Mhz is your video card running at?
Cologinbob
19
just wondering how far people were pushing thier video cards. mine is a
GeForce 2 Ultra
Core: 270 Mhz
Memory: 485 Mhz
rock solid performance at those settings. anyone going higher? Let me kknow.
Simulat
404
Ive got an Elsa Gladiac Geforce2. Clocked at 225/380. Dont use any extra cooling, that slightly too high for a regular Geforce2?
MTDEW
4,284
37
GeForce2 Ultra (Creative Annhilator2)
263/470
I'm still testing, pretty sure It'll go higher.
I'll give that 270/485 a shot.
Cologinbob
19
i do have extra cooling and have found it necassary to over clock you video card. i have a 120mm fan cut into the side panel which blows on the expansion cards and the processor. a little loud but works really well.
Losty
1,136
is there a difference in mhz in the raedon and the geforce? are they both ddr? you guys go pretty high...how do you know if it's not stabil? glitches? i have no temp readings on my card...grrrr....
asus v7700 64mb geforce 2
220/365
ahfung
1,418
Asus V6800 Pure GeForce DDR at 150/350, overclocked from default 120/300. Damn 0.25 process, it makes my GeForce f*cking hot.
chasm22
328
kimcheeboy;
Everything I have read says to keep the core and memory clock at the same speed on the Radeon. I see you have yours set up differently. How is it working? Is the Radeon LE different in this respect?
BW
Banned
Nov 28, 1999
254
I have my PowerColor 64 at 125 and if i had my 5500 in it would be at 187.
JayPatel
4,488
used to have an old Geforce SDR running at 175/220 using my own personal modifications.
