what material to use for kitchen countertop other than granite
Jul 10, 2007
12,041
i'm entertaining the idea of remodeling the kitchen in my current home.
i'd like to keep the costs low since i don't plan to stay here for more than 5 years, but i will be keeping the home either for rental or for my parents when they retire.
granite is obviously the safe choice but pricey. @ $100 per sq ft, my current 26 sq ft counters (including sink area) would run $2600.
what are other good options? i'm looking for something less expensive and low maintenance but has a similar look to granite/stone (no steel or wood).
limestone/quartz are almost as expensive, i might as well go granite.
how is corian, or formica?
DingDingDao
3,044
I've seen kitchens with butcher block countertops -- looks pretty awesome but could be pricey.
Like this:
Crusty
12,684
My house has silestone in the kitchen throughout, except for a wooden cutout/cutting board next to my stove.
highland145
43,973
6,338
silestone = quartz = just as expensive as granite?
No idea. Looked several years back and for some reason thought it was a better choice that real stone (staining, cracking). If it's going to be a rental and not for the folks, then formica.
Is there a Mrs. BlahBlah that has a say so?
Edit: fact sheet.
MiniDoom
5,305
we did silestone, it's nice that you dont have to seal it ever. it was cheaper than granite. If price wasn't a consideration I would go with stained and polished concrete.
Aharami
21,205
165
$100/sq ft is only for the top end granite like Black Galaxy. You can get granite for as low as $50/sq ft.
dullard
26,111
4,756
I know I'm the odd one here, but new laminate looks almost identical to the fancier materials, is nearly indestructable, and if you do destroy it, it only costs ~$3 per sq ft to replace. Why pay $2300 more than you need to pay, especially if you are going to use it as a rental eventually?
mugs
48,920
46
Where are you getting granite for $100 a square foot?
We bought our counters from a local place (http://www.marble.com/). They had 5 different price groups, and I don't think even the most expensive one was $100. The stone we bought was in a mid-range group and I think it was only ~$50 a square foot.
Home Depot was a lot more expensive.
Jeeebus
9,181
901
You can get granite for about $25/sq. ft.
Even the very expensive granite I've looked at has been around $80/sq. ft. At $100, you're looking at very expensive granite.
Generally, quartz (silestone, cambria, etc.) is more expensive than granite, but if you're looking at ultra elaborate $100 + granite pieces, then ya, I can see why you'd think granite is more expensive.
JulesMaximus
74,586
986
Like this:
And if you actually use it as a butcher block or cutting board it will look like crap quickly...not to mention, wood is porous and will be a breeding ground for bacteria.
I have granite and honestly I wouldn't go with anything else. I love it! Worth every penny.
Sep 12, 2004
16,852
59
86
We went with Corian.
It's quite a bit cheaper than granite. No complaints with the Corian but if I had to do it again I'd spend the extra and go with granite.
BurnItDwn
26,353
1,862
Laminate (Such as Formica) works well, and is dirt cheap compared to the rest of the options.
Downside of course is that it's easier to scratch and burn....
Solid Surface (Such as Corian) works well, and is usually cheaper than options like granite. It may look better than laminate since it won't have seams. Downside is that it too is easier to scratch and burn...
I've got Formica in my kitchen, and will be putting Formica in my basement in the back of the home theater for my popcorn maker and bar area (just a 48inch piece)
If I was building a new place, or wanted to spend a lot for "the best", I would go for engineered stone/quartz as it's the lowest maintenance, but granite would be an option too... That said, when I get around to refurbishing my kitchen in my current house, I'll probabyl just use formica, as I'll be doing the work myself, and I've never had any issues with formica in my lifetime...
