What makes Pine-Sol cleaners water soluble?
Status
Not open for further replies.
NeoPTLD
Pine sole is a viscous, transparent amber liquid containing approximately 10% pine oil. It is soluble in water.
Pine oil is like any oil and insoluble in water.
What allows pine oil to be in solution in pine-sol rather than an emulsion and why does the final product dissolve in water?
As Gibsons said, the alcohols will behave as surfactants to improve the solubility.
There's so little alcohol that I doubt it makes any difference. Isopropyl is pretty similar in solvency to ethanol. At such a small amount, I can't see it making much difference. You don't find salad oil much more soluble in beer (5-7% alc) vs water.
Another vote for "it's probably the propan-2-ol", acting as a cosolvent. It's quite a common cosolvent because it is cheap.
The conversion of free fatty acids to ethoxylates (or the use of ethoxylates) will also enhance solubility.
It's the combination of isopropanol (2-propanol) and the non-ionic surfactants, alkyl alcohol ethoxylates. Possibly lauryl alcohol ethoxylates, the same ones found in most shampoos, but don't wash your hair with Pine-Sol.
If you would like to read more about it here's a patent on Stable Liquid Cleaners containing Pine Oil: http://www.freepatentsonline.com/5866534.pdf
Status
