cphowitzer
hey guys..
What fan is the major source of noise?
Case fans?
CPU Fan?
VideoCard fan?
PowerSupply Fan?
Because currently my case runs at a huge sound level (1/2 of a lawntrimmer), and i cant really figure out which part is making so much noise, if not all together.
My dell i'm using right now is silent, almost cant hear even though im using it. The computer thats making noise can be heard from the basement (and its on 2nd floor)...
Im kinda leaning that its the PSU, or the CPU fan. If it IS the PSU, then do you think any of these are better?
My current one is L&C 450watt.
Ultra 400Watt UV Reactive ATX Power Supply with Clear Sides and Dual 80mm UV Fans 39.99CAN
PowerUp 400 Watt Dual Fan Power Supply 32.99CAN
Diablo 420Watt Aluminum ATX Power Supply 42.99CAN
Coolmax ATX Black 400 Watt Power Supply with Silent 120mm Fan 69.99CAN
Case fans?
CPU Fan?
VideoCard fan?
PowerSupply Fan?
