What kind of switch is the power switch on ATX cases?
gregulator
631
4
I am making my own case and am wondering what I need to wire up a switch to the motherboard. Anyone know this information or have a link? Thanks
Windogg
They are usually called Plunger switches. You can pick them up at most electronic parts stores.
Workin'
5,309
Electrically speaking, it is a momentary-contact pushbutton-type switch. If you ask for a "plunger" they will send you to the plumbing department because they will think your toilet is clogged ;)
Jiggz
4,329
Radio shack carries them. That's where I bought mine when I converted my old AT Full Tower case into ATX. You need to take a look on the size of the button you will be using the switch since they come in different size and forms.
