what kind of splitter do i need for the cable modem?
ElFenix
102,406
8,585
cable guy didn't leave a splitter here so now i can't watch tv. is it just a regular splitter or is it a high pass/low pass type thing or what?
ElFenix
102,406
8,585
i got two, just to make sure. well, really because i forgot to put one of them back and accidentally carried it to the register with me. and paid for it.
boyRacer
18,569
Sure... you forgot one was in your pocket huh... ;)
Iron Woode
31,361
12,849
Get a high quality digital type splitter with a cable modem, not some cheap radio shack special.
I use a good one for my setup.
conjur
58,686
digital type splitter? WTH is that?
Just get a low-loss splitter. Something like -2.5db should be fine...and, yes, Radio Shack carries them, too.
oniq
Banned
Feb 17, 2002
4,196
[Walmart Drone]Radio Shack doesn't exist. Walmart is the best. Go to Walmart[/Walmart Drone]
Shawn
32,236
53
Don't go with something cheap. Your cable speed and tv quality will suffer if you do.
Iron Woode
31,361
12,849
Forget radio shack for that stuff.
You have never seen a real high end splitter for digital cable signals have you?
Beller0ph1
1,302
Get a satellite splitter from RadioShack. It has the higher frequency response that you need for digital.
NoReMoRsE
2,078
Watching TV on the comp is fun, but the ATI All-in-Wonder Radeon sux0rz in terms of software and driver support.
IamElectro
1,470
Originally posted by: Sukhoi
Make sure it does high MHz ranges! Like 1000 MHz.
this is correct 900-1000mhz min. I dont think they sell these at Wally World try Ratshack
Banned
Feb 17, 2003
1,948
FALSE. cable SPEED has NOTHING to do with the quality of the splitter.
Ausm
14
I would get one from Radio Shack also
Ausm
Aug 16, 2001
22,505
4
I did, and everything works fine. Just get a normal RadioShack/CC/BB/whatever splitter for $5 - $10 and you'll be fine.
