What kind of power supply do i need for scsi case?
mystuffs
Banned
Jan 9, 2002
Hi, what kind power supply do i need for scsi case 7 bays? please send me a link. if you find it on ebay send me the item#
also it need a on/off switch
bozo1
6,364
Chances are that is the correct powersupply but without knowing exactly what case that is, there is no way to know for sure. There is no 'standard' for this.
That powersupply you linked to comes with an on/off switch but you probably will need to disconnect that switch and connect the power leads directly to the switch on the case.
AntecCSR
394
Ok from the looks of things you have an external drive enclosure (7 bay scsi box) so the AT power supply you linked to should work, although I don't know if you'll need to make any modifications to it. Beyond that you're only concern is hooking it up to your system. Since I doubt the case has room for a mobo/system as well.
AntecCSR
