I want to hook up one keyboard, mouse, and monitor to two computers. What works? Is there a switch that allows you to keep both puters running while you switch?
Try www.cyberguys.com and look unders Switchboxes for KVM switches. The best ones, like Belkin, allow you to switch back and forth using keyboard hot-keys. Buy a good one, not a cheap one, if you want to retain good video.
