What kind of fan should Iget for a 478 pin p4?
teleri
39
I have a th7II raid board being shipped now and need to know what kind of colling fan Ishould get for the cpu? does the 478 pin cpu use the same fans that the 423 pins use?
Bingo13
1,269
The retail Intel fan is fine and will still allow a decent overclock. If you plan on heavy overclocking then the Coolermaster DI4-7H53D is an excellent choice. I have a 1.8 running right above 2.0 with this cooler and it runs the same temps as the Intel at 1.8. The 478 pin cpus will use a different fan than the 423 pin systems.
