What kind of Fan Filter to get?
saltedeggman
3,775
from my experience, mesh allow freer air flow, with more dust as well. It is also eaiser to clean, i just rinse it with water....
foam is a bit more restrictive, harder to clean, but definitely keep the dust out
0roo0roo
64,795
84
just get a hepa room air filter machine;)
mod it onto your case for bonus points
as for those fan "filters"...they just keep out the larger bits, dust still gets in. the metal ones cost more, the foam plastic frame one has lousy design blocking too much surface area
Zepper
18,998
I use the plastic with foam. But then, I don't use it on the wimpy fans that are popular now...
.bh.
MadScientist
2,183
63
I use these aluminum filters on my intake fans. A bit more expensive than the foam filters, but very sturdy. I use a small vacuum to clean them without having to remove them. They are available in different colors in 80, 92 and 120 mm sizes.
Link
Liver
575
I have successfully used panty hose as a nice thin but dust trapping filter. Its really cheap too. To get it to stay in place a couple of dabs of hot glue work great. From the outside of the case it looks perfect, but from the inside you can see a couple of ragged edges.
starwars7
663
Wow, these are some relaly nifty ideas.
MadScientist: have you noticed any airflow problem with the aluminum filters? That seems like a nice longterm solution if it works.
Liver: nifty use of panty hose, how effective are they, about as good as foam or some other material?
Liver
575
There is a balance you have to reach between good airflow (cooling) and dust. I find the panyhose to be it. Good enough filtration without a significant impedence to air flow.
The fine fine dust will still get in, but the larger crap will not. Find that I may dust it once a year. I only dust it when I upgrade or need to open the case, and it is clean. The fans show some of the fine dust, but nothing major before the pantyhose.
Mrvile has the same recommendation, but I think the cheesecloth and nylon socks are heavier.
Take a fan out and run it with the various materials infront of it (depending on your air flow needs). See which one pushes (or pulls) more air through it, and realize it may be less once mounted in a case.
trexpesto
1,237
I washed and made one from a clothes-softening dryer sheet. Washed a little too hard, got kind of fuzzy.
dunkster
1,473
If you're willing to fiddle a bit with mounting thicker filter media, the pleated furnace filter media is very effective with minimal air-flow restriction.
Because it's pleated/folded for greater surface area, it's about an inch thick.
Unmeasurable flow restriction and very good dust capture.
The specific media I'm using is cut from a 16" X 20" X 1" filter by 'Columbia Industries', purchased from Home Depot.
Hope this helps!
