what kind of case temps do yall get NOT CPU temps
GunNut
Banned
I am running MBM 5 and was curious what kind of temps yall get.
i am geting 22C to 26 C are theses good?
These are not cpu temps!
Yeah, that's good! What's the ambient temp? How many case fans?
My temp is 35-37°C. The ambient is high, about 30°C
I average 23c to 27c for case temps. I have 11 fans total, including 4 80mm case fans. (Two are in blowholes.)
Comparing case temps with the on board sensors is meaningless unless you are talking about the same motherboard. Otherwise you are comparing the location and calibration of the sensors more than anything else.
I dont think he's makin some exact analysis. I think he just wants to get an idea.
I get 38C with a cpu temp of 48C AVIA 1ghz@1ghz 🙂 right now only one outake fan is running.
I have a fan blowing in, a fan blowing out, golden oeb on the cpu and fan on PS
I have no way of measuring cpu temp on my mobo, but with mbm5 i can monitor sensor temps, I am learning about cooling and just curious, the seemed low to me but i guess everyone is about the same
thanks
Current System Temperature (According to VIA HM)
CPU Current Temperature : 35C
System Current Temperature: 37C
heheh my processor runs cooler than system temp 🙂.... I've got a 92mm intake in the front and a custom cut blowhole directly over the processor with another 92mm... all my fans are running in 7v and I have a vertical powersupply that sits directly infront of the processor... she was overheating before that blow hole 🙂 now air comes in directly over the processor... the hsf blows it through a custom vent in my p/s and out the p/s fan... its bitchin...
