What kick-butt cooling system are you using?
CHiMPBizKiT
228
The chimp's curious to know what you guys are using out there. I'm looking to upgrade my system with some cool peltier/water-cooling as soon as I can. Share your fat HSF combo and narly cooling here! :p
goophie
286
i got a no-name cpu with a big 80mm fan strapped onto it... for my slot-a athlon
this thing gets hot! around 40 C idle!!
maybe the big fan isn't a good idea?
spamboy
Banned
Aug 28, 2000
1,033
I have a Katmai PIII 450 o/c to 1.13 Ghz on the stock heat sink with the thermal tape. Oh, yeah, and it's submerged in $1000 of Florinert. Just kidding. :)
Jeff7
41,596
20
Nothing yet, but I got a few 120mm fans; going to cut a hole in the side, and on the top of my Enlight 7237 case. Also built a little blower assembly that goes in a PCI case slot. Neat thing about it - it only cost me $2. :D
Bought a little blower, and epoxied it's exhaust hole over the hole in an old video card bracket. Nice, cheap little sucker...er, blower. :)
ZeroBurn
2,892
alpha pal6035 on my tbird 1.1@1.15 (and it's a week 53, how sorry is that? ;) ) w/ a 120mm alum panaflo intake, 92mm exhaust, and 80mm PSU. not much, and stock since the case is brand new but i guess since my chip is barely OC'ed it doesn't take much at all ;P
DDDavey
195
Zipperhead, kickass setup! I was thinking of the Q500 for quite a while, but after I saw yours, it just looked so pretty that I bought it :) could you elaborate on what you did? or what you have or anythin? I remember seein a while back that you used antifreeze or something...thanks!
Dave
ericd
355
Hey Zipper how much noise does your water pump make? Overall would you say that a watercooling rig is quieter than a HSF rig.
Eric
Zipperhead
1,277
this is what it used to be:
My system:
inwin q500 full tower case
asus cusl2 m.b.
p3 700 overclocked to 1085mhz
mushkin rev2 128mb ram
seagate ultra 160 15,000rpm 18gig h.d.
adaptec 29160 contoller
plextor ultraplexwide 40x cd-rom drive
plextor plexwriter 12/4/32 burner
asus v7700 64meg gts-2 video card
sound blaster live sound card
3com 905b nic
sony e400 19" flat screen monitor
going to be:
either a p3 with an asus cuv266 or an amd t-bird 1000,either way it will be pretty much the same except for m.b.,ram, and cpu
Zipperhead
1,277
ericd-it is almost silent.i run the 120mm fans at 5volts,can barely here them run.yes it is quieter than a hsf.
GroundOO
553
InWin A500
80mm blowhole(out) on top-middle, Sunon 92mm intake on front bezel.
I'm going to add 2 92mm or 120mm's on the side above the motherboard, inset in a window I'm also gonna add. (Right now there's also a window on the top, looking at the motherboard. I plan to add neon.)
When I get my A7V in the mail (PostOffice is crap, 4 weeks worth of crap!) I'm slappin' a Swiftech 72W peltier setup on my Duron600. I'll get watercooling going soonafter.
Tweakin
2,532
Sweet setup Zipperhead. I'm glad to see other people routing all the cables behind the MB Tray for a clean look. I love the water setup, but I just don't have the balls for that yet....:)
