What is your CPU temperature?
i5-2500k @ 4.5 Ghz
Vcore: 1.3
idle: 30 celcius
100% load (folding@home) : 67 celcius
Ambient: 22-23 celcius
Cooler: Corsair H50, though I should note that I got about the same temps using a coolermaster Hyper 212 during the summer.
I have done testing with folding at home and while its load temps are more comparable to normal everyday load temps with real world apps, it is probably 7-10c lower then you would get running a stress tester application...
Currently idling at 20-25c. Ambient temp is 15c.
100% load at 49c
Running an i5-2500k (stock speed) with a CM 212 evo cooler.
YOu definitely cannot be married or house your PC in the garage....15c is 59f....no woman would allow the house to go below like 73-74f....I would have my house at 69f if it was up to me....
My office is probably more like 23c...
About 58C when running Occt Perestroïka PSU stress test (GPU and CPU at 100% at the same time), which is the only way to accurately meassure full load temperature (it's like 48C with the AMD Overdrive Stress Test running).
Unfortunately, AMD CPUs are not allowed to go higher than 61C, so that's why I can't overclock any higher.
i5 2500 @3.3ghz with stock cooler : idle = 33c-38c , 100% load = 78c
with hyper 212 evo : idle = 25-30 , 100% load = 52c 😀
