Is temp variation on the cores like this normal? I have the same thing going on and the same cores seem to run hot on mine also. I was thinking of resetting my heatsink cause I thought it wasn't mounted properly to get such a wide variation.
lulz everyone is jumping smoblikat yet there leaving me alone with lower temps.. 😉
i feel so loved...
i feel so loved...
Ambient temp is 15c.
I am pretty sure he is only looking for comparable cpus. an AMD has completely different temp range compared to the 2500k.amd athlonII 250e
25 idle
35 under load
Completely normal, I would ignore anything up toabout 6-8 degrees difference between cores and from what I can tell nearly all SB chips do this.
Thanks everyone for their replies! It looks like most of your temperatures idling are about the same as mine, so I guess I did a good job on the thermal paste! 🙂
My 2600K peaks around 93-94°C at 5GHz and 1.5V under LinX with an H100.
FAIL!
dont ever look at others scores and think they can apply to you.
So many different variables come into play.
1. Ambients.. what is the temp right in front of your computer.
2. Ambients @ sink... what is the temp of the air your sink is pulling... can be higher then outside ambients.
3. What type of sink are you using?
4. What kind of Fans are you using and at what speed.
5. What Thermal Paste are you using?
6. Do you sing to it at night? Are u using an Intel Sticker on your case...
Ok 6 is a joke.. but the first 5 apply heavily.
Does that not get a bit chilly for you?
again the OP does not need to know what temps an AMD cpu gets.X4 965 @ 4.1 GHz.
Corsair H50 with two 120MM fans (push-pull).
High 20s / low 30s idle.
Mid-high 40s loaded.
Couldn't be happier. This machine is silent.
🙄I read the entire thread, thanks.
Oh, and welcome to my ignore list.
1100t at auto oc 3.8ghz 41cel on all 6 cores max load cinebench 11.5
Hyper 212 plus and artic silver 5.
Used artic silver 5 in so many builds and for friends it really helps out its a must have for any build i do:biggrin:
I do doubt my load temps but i used cpuid hwmonitor and apparently that never lies but my vcore is at 1.356 when fully loaded so maybe?
Build is housed in a antec 300 case fans on medium
lol, why are you posting your AMD cpu temps? that will not help the OP at all.
