What is wrong with my HD? PLease help!!!
ace31216
1,184
My computer all of a sudden died on me today!
I have two harddrives. Today, when I turned on my computer, no power was going through the system. I have the antec SX-830 and it tends to shut off the power if there is a lose cable or something. Any how, I unplugged all the cables and plugged them back in with fustrating results.
Finally, one by one with elimination, I found out it was traced to the harddrive. When the power cable is plugged into the Master primary HD AND Slave secondary harddrive, the whole system just doesn't turn on. However, when my Master primary harrdrive, (which I plugged in the power for ONLY and not for the second one), the computer boots up the system and it turns on. Unfortunately i get a error message and says put in boot disk and some other stuff.
I looked into the bio's and under the boot column, it dectects my DVD, burner, floppy, but no harddrive!!!
I took another harddrive from another system and connected it to and the bios saw it. For this reason, I'm ruling out the motherboard.
Can someone tell me what's wrong with the harddrive and if it is both HD's or jus one? Thanx!!!
Here is my system specs jus in case: IDE 30 gig Maxtor and 30 gig Western Digital
Asus a7v133
Antec case sx830
ojai00
3,291
Have you tried switching out the power supply for another one? Since you say that it works with one hard drive and not two, it could be that there isn't enough power to go around because of a bad power supply. Hope this helps.
ace31216
1,184
Thanks...that's an interesting suggestion. But it still doesn't explain why I can't see the primary Harddrive (when i only put the power plug for this drive), in the bios if the power supply is at fault.
Could it be something else?
