Confused
I have a 40gb hard drive here which i have loads of stuff as my storage drive. I got another computer, and wanted to put this hard drive in it, so i put it in and installed Windows XP Pro on the same NTFS partition as i formatted it as in my old Windows XP computer. I got Win installed on it, and then last night the computer crashed. I reset it, and it seemed to be OK, but when i got up this morning i was greeted by a nice BSOD. 🙁 So, i reset the computer, and when it gets to the WinXP splash screen with the moving bars at the bottom, the same message came up.
Here's the message:
I have also put this hard drive as a slave in another computer and when it gets to the WinXP splash screen with the moving bars at the bottom on this different computer the same happens. 🙁
Does anyone have any idea what's wrong and how i can fix this and get the info back off this hard drive?
Thanks in advance
Confused
Here's the message:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Disable or uninstall any anti-virus, disk defragmentation or backup utilities. Check your hard drive configuration, and check for any updated drivers. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
Technical information:
*** STOP: 0x00000024 (0x001902, 0xFBC4B814, 0xFBC4B514, 0xFB6C6A4E)
*** Ntfs.sys - Address FB6C6A4E base at FBC1000, Datestamp 3c587aa0
Thanks in advance
Confused
