Question What is up with Ryzen Master and virtualization?
Thunder 57
4,278
7,088
This has been going on forever it seems. You cannot use Ryzen Master if you have AMD-V enabled. I do not see why the two cannot be compatible. I don't use either very much but it seems stupid to have to go change a BIOS option to use one. Does anyone know why or what is going on here?
lightmanek
524
1,292
It works for me.
Granted, RM is a diva and in one instance I had to do full bios reset before it would open ...
Thunder 57
4,278
7,088
It works for me.
And you can run a virtual machine while being able to use Ryzen Master? Maybe it just a thing with Zen(+) CPU's if that is the case. I thought @Markfw had the same problem though.
moinmoin
5,248
8,463
It's not virtualization altogether that needs to be turned off, but just "Virtualization Based Security (VBS)". It should be possible to disable just the latter, it's just the usual typical unintuitive Windows mess to do so, see:
Thunder 57
4,278
7,088
I will try that the next time I reboot. Looks like the answer.
lightmanek
524
1,292
Yes, I run VMware Linux and Windows XP systems on a regular basis and can change my Ryzen's parameters on the fly.
Reactions: DAPUNISHER
Thunder 57
4,278
7,088
Sorry to be a bother, but I am still having trouble. VBS is disabled in Group Policy. I'd rather not mess with much else until I know what I should be doing. I don not want to go disabling components unless I feel comfortable. It sounds like VBS alone should have done the trick. It was already disabled when I looked for it in GPEdit.
