It's not the gasket, it's the cover itself that's cracked. I know because I did it. My dipstick handle broke off, which seems to be a common issue on Dodge vehicles judging by a Google search about it. The most common way to fix was to drill a pilot hole into the remaining plastic stuck inside the dipstick tube, screw in a screw and pull it out. Tried that, wouldn't come out, so I got a hammer to pry it up like a nail, to get some leverage. I leveraged the head of the hammer against this valve cover because I thought it was solid metal, but I was wrong.
It's slightly cracked but the picture you see is from just running the car in the driveway and holding at 2k RPM for about 30 seconds. I'm not even sure if I should drive it at all now.
