- May 9, 2004
- 8,443
- 124
- 106
Is it? I thought it was an 8 shader part.Isn't the GT120 almost like a 8600GT? 32 shaders, 128bit DDR2. I'm pretty sure it's quite a bit faster than a 6800GS which was kinda sucky when it showed up to begin with... It wasn't terribly bad, but it sure wasn't a speed demon either GT120 link
I'd say it's X1800XT > GT120 > 6800GS
Is it, from fastest to slowest:
1. X1800XT 512MB
2. GT120
3. 6800GS 256MB PCIe
well you would be wrong then because a gt120 would walk all over a 6800gs. except for 35% less memory bandwidth and slightly lower core clock, a gt120 is basically a 9500gt which is well over twice as fast as a 6800gs in modern games. a 6800gs couldnt even begin to play modern games at higher settings than a gt120 could.I'd rank the GT120 last, based on mem bandwidth alone.
It would mostly matter what you are running to benchmark the cards, but the gt120 would be starting off at 1/2 the mem bandwidth compared to the 6800GS. That's too large of a handicap to overcome imo.
http://users.erols.com/chare/video.htm
X1800XT 48GB/s
6800GS 32GB/s
GT120 16GB/s
It's like you took the words right out of my mouth. I read that one and thought "Well, that could have been a lot worse."way to let him down easy
exactly right. the gt120 is basically a memory bandwidth crippled 9500gt. that reduced bandwidth still does not allow the 6800gs to come close to matching the gt120s performance in modern games though.It's like you took the words right out of my mouth. I read that one and thought "Well, that could have been a lot worse."
To keep in topic, I believe the GT120 just has too many SPs (32?) compared to the 6800gs, so the 6800 can tout its higher bandwidth all it wants, but too much raw SP power is on the side of the GT120 versus the 6800gs.
you would take the memory bandwidth for what? its a FACT that a 9500gt is well over twice as fast as a 6800gs. a gt120 is a 9500gt with 10% less core speed and 35% less bandwidth. do you really think reducing the memory bandwidth by 35% is going to make the gt120 lose every bit of its performance and then some? its not going to happen and a 6800gs will not touch a gt120.I see you people are fast to disregard parts of my post:
"It would mostly matter what you are running to benchmark the cards"
I didn't make a blanket statement.
I'd take the mem bandwidth personally.
the comparison reminds me of the fx5200 vs. the ti4200
If you disagree show some benchmarks![]()
1. X1800XT 512MB
2. GT120
gpu clock mem bandwidth GP/s GT/s
gt 120 500 16GB/s 4.4 8.8
6800 gs 450 32GB/s 3.4 5.1
-11.1 +100% -29.4% -72.5
I pulled the GP and GT numbers from wiki, and checked against nvidia's
other notes: can't compare the different cores or their SPs directly. They are different designs:
gt 120 32:16:8 Unified Shaders (Vertex shader / Geometry shader / Pixel shader) : Texture mapping unit : Render Output unit
6800 gs 5:12:12:8 Vertex shader : Pixel shader : Texture mapping unit : Render Output unit
as the 6800 didn't have a unified shader model you aren't really comparing 32 SPs to 12 SPs
would be more like comparing 32 to 29 if you add up the dedicated vertex, geometry and pixel processors
again it really depends what you are using to benchmark the two (the op didn't specify)
yep. for modern games all those cards are quite poor. heck a 6800gs doesnt even meet the minimum requirements to play some newer games.1.crap
2.crapier
3. crapiest :biggrin:
The X1800XT can still play modern games fairly respectably, albeit maybe with lower AA or no AA at higher details on 1680/1920 settings.
The GT120 is almost useless outside of HTPC duties, just like the 9500/9400/8600/8500/etc.
The 6800 was a great card in it's day, but that day was a looooong time ago. When did the 6000 series come out, like 2004 or so? That's gonna be six years ago in a few months.
X1800xt can barely play Bioshock @ 1650x1050.
Recommended Requirements
CPU Intel Core 2 Duo processor
System RAM 2GB
Video card DX9 Direct X 9.0c compliant video card with 512MB RAM (NVIDIA GeForce 7900 GT or better) / DX10 NVIDIA GeForce 8600 or better
Sound Card Sound Blaster X-Fi series (Optimized for use with Creative Labs EAX ADVANCED HD 4.0 or EAX ADVANCED HD 5.0 compatible sound cards)
That was 2007.
