What is the right size hole saw for a 60mm fan? 80mm?
Gorham
38
Was planning on using a bi-metal hole saw for a side blow hole in my case. Can anyone reccomend the correct size for a 60mm and 80mm fan?
Gorham
38
All the hole saws I see are described in terms of inches 1 1/2, 2 1/4, etc. (not MM)
My conversion of the metric system to inches is horrific, but as near as I can tell, 60 mm = somewhere around 2 3/8"
I was looking for confirmation that this would be correct and that the hole does not need to be made any larger than this.
Similarly 80mm translates to 3 3/16 so I wanted to make sure that 3 1/4" would work alright.
