Built a rig last Xmas and am quite happy with it, but I have an awful lot of noise from case fans (2), and I think I probably skimped a little. Can anyone recommend a good quality, low noise fan?
rayjay
Pabst fans are generally known as the quietest case fans although they are much more expensive than a lot of other fans. Panaflo's are also good and quiet and don't cost as much. I bought a couple of 8cm pc power & cooling silencer fans which are rated 1600rpm, 28cfm, and 20db. I'm pretty sure those specs are better than the panaflos although I haven't actually heard either one so I don't know which one actually sounds quieter.
Check out Gizzo's Fan Page. It has a lot of different fans along with cfm and db ratings. Check the ratio to see which ones have the best cfm-to-db ratings. The PC Power & Cooling fan has the 2nd highest ratio behind a papst fan.
QuietPC's 28 cfm @ 20 dba (Re-badged Papst/PC Power and Cooling, very quiet, but I think the 28 cfm is over-rated)
Panaflo's 24 cfm @ 21 dba (under case fans, 80 mm fans - Just got two of these Thursday, haven't built the system they're intended for yet. Seem very quiet, & push roughly = air to the QuietPC fan)
I got 3 pabst 19 db 80X80mm fans. Although I should have had some more cfm instead of low noice. The system does make some noice, and I want to cool it down well enough... Im thinking of bying some 26db ones for my computer. Becuase im going to build a near silent pc soon, and to cool it down enough I might use the pabst ones I got.
