Yeah, 2uA sound about right with the power plugged in and standby voltage present. Try measuring the current from the battery with the power off (I mean unplugged - IOW, with the PSU switch turned off or totally unplugged). It should be higher as I believe the typical CMOS power circuit should look like this:
. v-CMOS battery
o--Ground -----|i|i|i---->|---o---o to CMOS chip
............................diode ^...D - diode
o---+3.3V from system---|
. The Li coin battery isn't rechargeable and the +3.3V from the system should keep the battery from participating much in the current supply to the CMOS when the standby or regular 3.3V is present. If you turn your machine totally off much of the time such as with the switch on the PSU, switch on a surge protector or unplug, then the battery may decline faster.
. The "...30 uA... " article must be really old as I haven't seen an external battery connector on a new mobo in years. IAC, the battery you buy WILL have a great impact on longevity. Make sure you buy Li coin batteries made in USA, Japan or Switzerland. I get Duracell made in Japan at Staples for approx. $2. every day. In my experience with watches and computers, those made in China will have a much shorter life. Not too familiar with Taiwanese coin batts. Name brands (Duracell, Energizer, Maxell, Panasonic, etc.) usually have a shelf-life date on the package which provides some reassurance. I try to buy with 2 yrs or more left.
. And be sure you're buying the right battery. The equivalent to the
CR-2032 (220 mAh (milliAmp-hrs)) is the one you want, the
BR-2032 version has 30 or more mAh LESS capacity and the CR/BR-2016 (which on casual inspection looks about the same size) is less than half the mAh capacity (BR/CR = 75/90) (all ratings here are Panasonic specs). So the CR-2032 could ideally last for about 13 yrs at a your constant 2 uA drain. The Panasonic chart for the CR-2032 says the standard drain is 0.2 mA, which is 100x what you measured. So you must be buying Chinese batteries of the wrong type/rating...
.bh.
