What is the max length of an HDMI cable?
NuclearNed
Raconteur
May 18, 2001
7,869
361
I would like to mount a plasma tv on the mantle above my fireplace. Because of the layout, I may have to run an HDMI cable as far as 15 feet. How much of a problem will that be?
Also, does anyone sell HDMI/DVI wall recepticles? I will need to run a cable through the wall. On one end I'll need to connect it to my DishNetwork HD box, and on the other end I'll want to connect it to the tv. I would like to make this installation look as nice as possible so I don't have visible cables everywhere.
NuclearNed
Raconteur
May 18, 2001
7,869
361
crap - I thought I was posting this in the av & home theater forum. Are there any friendly mods who would like to move this?
Pakman
807
I thought HDMI was digital... so you will either have a signal or no signal. I would assume that if they sell a 15ft. hdmi cable, it should work. Check www.monoprice.com.
NuclearNed
Raconteur
May 18, 2001
7,869
361
Thanks guys. That is exactly what I'm looking for. I think I'll buy a couple of those, then commission my wife's uncle to make a couple of stained oak recepticle covers so they'll blend in with my other woodwork around the mantle.
James Bond
6,023
Just because it's digital doesn't mean there is no attenuation.
TheAdvocate
2,561
7
Originally posted by: AmpedSilence
why are the 6 ft cables on monoprice less expensive than the 1.5 ft or 3 ft ones? that seems odd.
Common size. economies of scale. ~ $0 variable cost for n+1 production.
Did you sleep through econ class? :D
AmpedSilence
2,749
I figured that it was economies of scale that was allowing a lower price.
Oh, I never took an econ class, but if need you DNA isolated and finger pirnted i can do that for you :p
Specop 007
9,454
About all I'm good for is eating your food and leaving my clothes lying around the house. (At least according to my wife anyways).
