What is the file system type for smart media cards? ("mount -t auto" says no dice)
Buddha Bart
3,064
I'm trying to get my card reader working on my redhat 7.3 machine, and when I issue the mount command it wants me to specify what file system type. Anyone know what the answer is? Its an Olympus D-520 zoom camera that wrote to the smartmedia card if it matters.
bart
corkyg
Elite Member | Peripherals
27,370
239
Olympus cameras use standard FAT in SmartMedia. I didn't know Linux was so spastic. What's this "mount" stuff? I just plug my reader into USB - it goes "bing-bing" and is ready for use as a lettered drive. :)
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
16
Generally removable media uses FAT12 (not FAT16, or the regular FAT32).
Electrode
6,063
just specify msdos as the filesystem. The Linux FAT driver will recognize the FAT12 filesystem.
If you ever want to format the smartmedia card, just use mkdosfs -F 12 to ensure you get a FAT12 filesystem. Note that windows doesn't give you this choice. :)
Nothinman
30,672
Run 'file -s /dev/whatever' and see what it says, file has magic numbers for a lot of file types and the majority of filesystems.
Drive letters are so 90's.
Buddha Bart
3,064
thanks nothingman, i'll try that right now. In the mean time, I think I have another problem concurrent to that. Can anyone make any sense of this?
Sep 19 23:44:28 boondock kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Sep 19 23:44:28 boondock kernel: sda : READ CAPACITY failed.
Sep 19 23:44:28 boondock kernel: sda : status = 1, message = 00, host = 0, driver = 08
Sep 19 23:44:28 boondock kernel: Current sd00:00: sense key Not Ready
Sep 19 23:44:28 boondock kernel: Additional sense indicates Medium not present
Sep 19 23:44:28 boondock kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
Sep 19 23:44:28 boondock kernel: sda: I/O error: dev 08:00, sector 0
Sep 19 23:44:28 boondock kernel: I/O error: dev 08:00, sector 0
Sep 19 23:44:28 boondock kernel: unable to read partition table
[edit]
Darn, didn't work.
[root@boondock dev]# file -s /dev/sda
/dev/sda: file: read failed (Input/output error).
[/edit]
bart
Nothinman
30,672
Looks like it's not seeing the media. Have you tried the media in another box/OS to make sure it's good?
Buddha Bart
3,064
yep, i just transfered the stuff to onto my laptop at work (win2k).
I can't use my windows desktop at home because the moment any operating system tries to load its usb mass-storage driver it flips out and freezes. Good old VIA chipsets.
bart
