What is the ethernet card on the Laser printer for ?
TurtleMan
1,424
Just said i have a small network, do i just connect a cat5 cable to it and link it up to my router
and I will be able to use ? is that wat it is for ? thanks !
Mar 8, 2001
115
Are you using TCP/IP to make your connection to the printer? If so you'll either have to assign an IP address to that card or switch to a compatible network protocol to communicate to it like IPX. Treat it as if it were another PC. What ever you have to do to get your PC on the network so others can see your shares you'll have to do the same to that printer.
There's a few different ways to connect to it then once it's on the network. You can use a Server to manage the queue, a router/Print server device, or directly connect to the printer using the IP address. Using the IP address, it should be "\\IP Address\Queue Name" but without the quotes. Your documentation should tell you what the default queue name is. I think on HP Laserjet jet direct cards it used to be just LP for the queue name.
It will use your CAT5 cable.
TurtleMan
1,424
umm cuz at home i have the SMC router with have a paralle port i can connect to it,
but i have to install port thing so i can use it,
I was wondering if it would be the same ?
And wat is "You can use a Server to manage the queue, " i don't have to do that rite¡H?
