I just replace the original HP cooling fan
with this
Original Fan was dying on me causing Laptop to shut down
I know they both rated for 5 volt but don't know watt and Amp plus CFM.
Thanks
Mir
One uses 1.75W of power. They are both 5V. The other draws up to 0.40A of current. 5V x 0.40A = 2.0W.
I would venture that the two fans, if the same size and mounting standard, would be interchangeable for most purposes.
Generally, the CFM of a fan would be determined by size, speed, and to some variable and lesser degree -- by fin design. If the fans are the same size and thickness, they will spin in an approximate range of RPM -- likelier the beefier 0.40A fan a little more. So I would expect the second fan might have slightly more CFM. If the fans are different sizes and thickness, I wouldn't bet on my own guesses -- and I probably wouldn't make any.
