What is the difference between Geforce GTS and Pro?
aznmist
1,134
I also want to know if the Geforce 2 can use it's 64 megs of ram. I know the the Geofroce 2 MX 400 has 64 but the additional 32 meg is not put too goo use.
MilkPowderR
Banned
Mar 30, 2001
529
There's difference betw. GeForce2 GTS and Pro.
GeForce2 GTS 32mb vs. 64mb: almost no difference and 32mb will par or outperform 64meger upto 1024x768x32 bit in many games I belive. So yes, that extra 32meg will hardly be used if the graphics setting/intensity is not asking enough. You'll start to see using up the rest of that extra 32mb when you get into higher resolution and/or intensity of what's happening in the game but you'll not see much of performance advantage.
GeForce2 Pro which only available in 64mb and this one does have considerably higher memory bandwidth so it does have quite a bit of improvement in running heavy games over GTS 32/64mb. Pro is way to go. It tries to compete with the GeForce2 Ultra sometimes.
kintama
Banned
Jan 28, 2001
652
They do make a 32m pro card. Creative Annhilator 2 is a pro card. Pro's also have faster memory than the regular 2 GTS. I belive it is 5.5 or 5n's.
Simulat
404
Pro's should have 5ns memory. Clocked at 400mhz by default instead of 333 or whatever the Geforce GTS is at.
