What is the difference between DVD-R and DVD+R?
LiLxJohnny
Besides that these are two different formats supported by different companies, what is really ultimately the big difference between them (if you know what I mean)?
As I understand it, DVD-Rs are good for DVD Video and is more likely compatible with older standalone dvd players. DVD+Rs are very good for data however, if used for DVD Video, only "newer" players can read them. This may also be true for DVD-ROM drives as well?
Are there any differences? Advantages to either formats?
If anyone can shed light on this, please let me know.
DVD FAQ
Personally, I've always heard that it's best to go with DVD-R for compatability with older players. However, support for DVD+R is gaining, and most newer players can play all formats with no problems.
Another option is to get a burner that supports bitsetting (some Lite-on drives), and you can set the final format using a program. For example, using my Lite-on burner, I always set the format to DVD-ROM, regardless if I use +R or -R media.
There are many posts about this in General Hardware, you may want to do a search.
But to keep it short, DVD+R is the better format with better error correction. Especially with the bit setting, it can look just like a DVD-ROM. I have yet to run into a DVD player that hasn't played either one. DVD-R is bigger by a like 7MB or something like that. But I just buy whatever is cheaper.
