What is the difference between DVD+R and DVD-R?
Nab
802
I was currently in the market looking to purchase a dvd recordable drive and i came across DVD-R and DVD+R terms. Can someone explain the difference to me? Thanks.
Lager
9,433
Nothing if your burner can support both formats and the best price you can find on the media (I've always noticed DVD-R is cheaper then DVD+R).
boran
1,526
Why DVD+R is superior to DVD-R
I strictly use DVD+R and make sure all my target devices support it. if you want data to be stored for a looong time you'd want DVD+R and not DVD-R (while you're at it, get tayo yuden media (verbatim data life plus made in jap is tayo yuden, and all plextor DVD's are tayo yuden discs)
the higher ECC bit value mentioned in that article might explain those 7 megs -R has over +R
Nab
802
ahh, everything is cleared up. for my purposed they're basically the same thing. Thanks a lot. Much Appreciated.
