What is the difference between Burn-Proof & JustLink?
bearmeat
What is the difference between Burn-Proof & JustLink? It sounds like they are the same thing, are there any differences at all?
But they both have the same end result. They stop a CD write from failing if you get a Buffer Under Run.
There is also Safe-Burn that is also functionally equivilant.
They are not exactly the same, but close enough to suit your purposes (now I'm just being nitpicky)
