What is the best sound chip on motherboards?
sparks
535
I'm almost in the market for a new motherboard and I believe that I can live without a sound card id possible. What sound chip is currently the best one out or are they all basically the same?
Sheninat0r
515
Some motherboards from, I think, MSI [check that], come with X-Fi as their integrated sound. That sounds like your best bet unless you want distortiontastic Realtek AC'97.
The Keeper
291
I'm a bit curious of this myself too, because I'm going to skip on buying a dedicated sound card. X-Fi's have poor drivers, new Razer and Asus sound cards just costs way too much.
Gigabyte's P35 boards (I have one ordered) have ALC889, which I think should be top class as far as onboard sound chips are concerned, right?
j0j081
Banned
Aug 26, 2007
1,090
yeah I think the newest Realtek HD audio chips are the 888 and 889 although 883 is meant to be pretty good to. Much better than the old integrated solutions.
Peter
9,640
A lot of the quality in any sound solution is a matter of the mainboard's layout and the choice of analog components around the sound chip. You can always make an awful sounding solution from the best chip available.
Same goes for discrete sound cards of course - just that it's easier there, simply because it's further away from the big sources of digital noise.
jonmcc33
Banned
Feb 24, 2002
1,504
How can anyone put the letters "HD" with "AC'97"? Being that any chip is on the motherboard and suffers from interference I wouldn't say the sound quality is good on any of them.
Peter
9,640
Well, for one it isn't inherently impossible to get an onboard sound solution isolated from noise properly. It's just that some mainboard designers aren't exactly trying too hard.
trOver
1,417
just get a cheaper mobo and a dedicated sound card.
ht omega claro ftw
Doclife
414
I'm using onboard audio of the Gigabyte's P35 motherboard (GA-P35-DS3R, revision 2.0). The onboard audio is superb (I listen to music on my computer a lot). I would say that it is equal to or may be better than the M-Audio revolution 7.1 sound card that I have on the other AMD computer of mine. I think this is the reason why Creative's stock is going down the drain lately. There is absolutely no need to buy a separate sound card when the onboard audio is that good, sound quality wise.
and yes, the onboard audio chip is ALC889A (support Blu-ray/HD DVD audio, 7.1 HD audio output)
Modelworks
16,240
7
You can put the sound chipset on a card or on the motherboard they are both going to pick up rf noise. The sound chipset on the board might even actually pick up less noise because it is closer to the ground plane.
Anyone ever read the reports on placing a video card and sound card next to each other in a pc case ? Its pretty clear why professional sound cards used for recording usually locate the hardware outside the case of the pc and just use the pc for an interface card.
gba
833
yup
j0j081
Banned
Aug 26, 2007
1,090
anyone know if the ADI AD1988B chip that is one some of the more expensive Asus boards is better than Realteks hd audio solutions? I'm trying to figure out if that is part of the price premium on certain mobos and if it's worth it.
The Keeper
291
I dislike ADI chips myself because the drivers for it will be only provided by the motherboard manufacturer. They may not even keep the drivers up-to-date, and it is only matter of time when they will no longer provide BIOS and driver updates for a particular motherboard model.
At least with Realtek, driver updates are pretty much guaranteed.
That is very nice to know, especially when I have just the same model (GA-P35-DS3R) on order.
Zap
22,377
HD audio (AKA Azalia) is not the same as AC'97. I'm coming from a VIA Envy24T chipset PCI sound card (most recently used) and to my ears using my mid-range stereo pair of speakers, I cannot hear a difference between the VIA chipset card and onboard HD audio.
I'm willing to wager (my old sound card, LOL) that the majority of people will be unable to hear a difference between onboard HD audio and an average (Audigy?) PCI sound card. Of course this needs to be done double blind and using that person's normal listening gear (speakers, headphones, whatnot) and with the output from both solutions normalized and with all equalization off.
postmortemIA
7,721
40
I could notice BIG difference through pseudo decent speakers (Logitech). In games it is 10x worse with software 3D emulation, it sounds like N64 on mono speaker.
Perhaps it is like every other art, the difference you are not noticing is because you are not good listener?
Even through change from Audigy 2 to X-Fi I've noticed that sound is bit better, more rich.
RanDum72
4,330
Thats why he suggested a double blind test. Knowing that you are going to upgrade from an Audigy 2 to an X-fi by itself already 'conditions' your brain that you are going to see an improvement. If you just have somebody listen to a bunch of computers without them knowing whats running the speakers will erase any 'pre-fabricated' conditioning. Of course, you will notice a difference going from really crappy sound to awesome sound but a decently designed sound card running a decent set of speakers will satisfy 99.9% of anybody's audio needs. Its that 0.1% that are really anal and nitpicky that will NEVER be satisfied..hehe (I happen to be one of them). Like they said, sound quality is subjective.
RanDum72
4,330
Sound quality-wise, ADI had a better reputation for sound quality that Realtek. The older Intel OEM mobos had a reputation for good quality built-in sound because of teh ADI chipset. I don't know if C-media is still alive in the motherboard built-in sound market.
Anybody knw if Cirrus Logic is still making sound chipsets for the PC? I remember when the TurtleBeach Santa Cruz (with Cirrus Logic chipset) gave the Audigy a run for its money in terms of features and sound quality.
Synomenon
10,547
He said "the majority...". No need to speak up that you're one of the few that can hear the difference.
The ALC88x series from Realtek are more than enough for those who aren't in the professional audio industry and the small number of people of have audiophile ears.
postmortemIA
7,721
40
Cirrus still makes DA converters that Creative still uses, but no new sound pc chipsets
BTW Santra Cruz and other CS 4624/4630 based cards are not supported in Vista.
RanDum72
4,330
Well, the SC last drivers was from a few years back and they didn't even guarantee support for winXp SP2 so I have no delusions about Win Vista:)
BTW, I still have a SC running in a 850E chipset RDRAM system..still sounds great after all these years.
yehuda
83
Gary noted on severel occassions how he likes the 889 better than the 888 and 883. Personally I was pleased with the analog ports on Gigabyte's 690G ATX board, which uses the 889 chip.
The ADI one from ASUS is faster in general while playing game because it does NOT support EAX.
Actually this is to the contrary, at least as far as EAX goes. Analog Devices supports proper EAX 2.0 whereas Realtek does not. See here:
http://techreport.com/articles.x/11171
http://techreport.com/discussions.x/12449
j0j081
Banned
Aug 26, 2007
1,090
that is talking about one of the older Realtek solutions though not the newer 888.
