What is the best silent closed loop cpu cooler
mitch2471
7
Hi there
I'm looking for a little advice/help selecting closed loop cpu cooler.
It is going to be for a I7 2600k which will be fitted into a Silverstone FT03 which means the rad/fan size is going to have to be limited to a 120mm kit.
It is mainly serving as a media center so the cooler needs to be very quiet.
I' not worried to much about fan noise as I will more than likely swap out what ever fans it comes with but am more concerned about the noise made by the built in pumps. I did once have a corsair h50 which worked amazingly well by had a very annoying hum from the pump.
So can anyone recommend a good cooler that bar fan noise is silent?
Thanks in advance.
dma0991
2,723
Almost all AIO units are manufactured by Asetek using similar pump design. The real problem is that its an anemic pump trying to push a lot of water and it has to spin much faster than custom WC pumps do.
