What is the best quiet fan?
xZero
Right now im using a 60mm 50cfm delta on my thermalright sk6 heatsink (on a 1.4ghz tbird). It sounds like an airplane :D Anyways I am looking around for the quietest 60mm fan that still does a good job......I dont want my cpu temp rising so much. Thanks in advance.
minendo
35,560
22
I put an 80mm Panaflo on my SK-6. It is keeping my xp1800+ (running at 1610) at 44C under full load. See the link in my sig for full system details.
xZero
how did you fit an 80mm fan on it? my sk6 only came with 60mm attatchment clips?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
<< how did you fit an 80mm fan on it? my sk6 only came with 60mm attatchment clips? >>
on an angle...
xZero
I dont understand what you mean by on an angle...could you please explain or show me a picture?:confused:
Yossarian
18,010
Heh same here xZero, I just put mine on about an hour ago. What he means is rotate the 80mm fan 45 degrees so the sides aren't parallel to the heatsink.
xZero
I still dont see how the clips would fit on the fan to hold it on the heatsink so it wont blow away?
okra
12
If you don't want to mess around w/ the 80 mm on the angle, you might want to check out papst fans - they're pretty quiet, not sure if they'll have the airflow you're used to though.
SWScorch
9,520
very bad diagram
Sorr that sucks so much... I dont feel like disassembling my computer and putting a 80mm fan on, otherwise I'd do it and take a photo to show you. Hopefully that will give you an idea how to put an 80mm fan on the SK-6. The red is the heatsink, and the blue is the fan.
jiffylube1024
7,430
<< I think thats the first time I have ever seen windows paint program come in handy >>
Actually I think he used the sophistocated filtering of Adobe Photoshop for that one. Yeah right :).
Crucial
5,026
You dont need zip ties or any extra means of attachment. Just rotate the fan 45 degrees and push the clips over the corners of the fan. It mounts just like the 60mm fan except the fan is rotated to fit. The M$paint diagram did a good job at showing how this is mounted
