What is the best Netgear RT314 firmware to use?
WyteWatt
Banned
I heard it was 3.24 because 3.25 has problems or something i thought i heard. Wondering if 3.26 is coming out anytime soon to fix these 3.25 firmware problems? I did notice 3.24 being more stable than 3.25 for some reason. 3.24 just seems more solid of a connection. 3.25 would do some strange things.
Please reply
Thanks
V3.25 ...I used to have problems with it dropping the WAN access but not once since upgrading the firmware to this version. Just a reminder, you might want to update it sequentially, I had problems when I upgraded from 3.20 to 3.25. Maybe it was my mistake but thats how i got it to work.
Craig
I did upgrade sequentially when i went to 3.25 firmware.
I went from 3.24 to 3.25. But for some reason it dropped connection off every now and then where the 3.24 doesn't ever. I wish 3.24 firmware had port range forwarding. 3.24 only has port forwarding with one port like you can only say port for ex. 1 if you wanted to open that you can't go 1 thru 10 like on 3.25.
