What is the best LCD TV monitor?
ricleo2
1,122
11
As I understand it an LCD TV Monitor can show High Definition on my computer. If this is true, what is the best on the market? I have an over the air antenna cable to my TV Tuner card now.
MSI K8N NEO4 SLI/PREMUIM MB
COOLERMASTER CMSTACKER CASE
2- BFG 7800 GTX OC VIDEO CARDS
2 STICKS OCZ EL 512MEG DUAL CHANNEL 2-3-2-5
2-WESTERN DIGITAL RAPTORS HD SATA
1-WESTERN DIGITAL IDE 40 GIG
ENERMAX 600 WATT NOISETAKER POWER SUPPLY(sli ready)
1-PLEXTER DUAL LAYER DVD WRITER
1-SONY DVD READER
1-SONY FLOPPY DRIVE
MICROSOFT WIRELESS KEYBOARD AND MOUSE
SOUND BLASTER AUDIGY 2 SOUND CARD
LOGITECH 5.1 SPEAKER SYSTEM
LEADTEC TV TUNER CARD
CANOPUS PCI CARD TO CONVERT ANALOG VIDEO CAMERA TO DVD
AMD FX-55 CPU
VIEWSONIC 19 INCH P95F+
imported_ST
733
Hmm you can be the first one in the US (maybe the world) to get CMO's new 56" LCD panel with display of 3840x2160. That's probably THE BEST right now. WIll probably run you around $50K, maybe a little more change.
Good luck...
ricleo2
1,122
11
Well, actually, I am looking for one that will fit on a computer desk. What you suggested does sound intriguing though,
jiffylube1024
7,430
It all depends on what you're trying to do with the monitor. If it's just for HDTV, then a high end DLP or LCD projector with screen would look amazing, as would a super large LCD TV. However, if you plan on using the monitor as a computer monitor as well, you'd be much better off with a true computer monitor that can do HD resolution, like the Dell 2405fpw or the 30" Apple Cinema Display.
ricleo2
1,122
11
I want to use the LCD monitor as a HDTV and like a regular computer monitor. I also enjoy gaming. Does such a monitor exist?
ricleo2
1,122
11
What I am looking for is an integrated HDTV-capable tuner built in the LCD monitor, one that will fit on a computer desk, one that is great for gaming, and lots of video editing. Does such a monitor exist? Thanks.
robp5p
4
I have an OTA HD tuner going to my 2405fpw's component inputs, works nicely
SectorZero
Bought a Samsung 46inch DLP TV last year. I bought it because it had the best picture quality of all the sets on display. Not only does this TV have a DVI port to hook up my DVD player, to my surprize, it also has a standard 15 pin VGA port to hook up directly to a PC.
I have a computer connected to the TV right now. The display is perfect. It's just a really big computer monitor. We play games on it, surf, watch DVD's on it playing on the computer.
But I have to say, the ultimate is the Fireplace screen saver. I like to run the screen saver and just let it go. Call people over and let them gasp in awe at it.
Wireless KYB and mouse is a must for this set up though.
Playing poker on the internet is now a social activity. It's a blast when a bunch of buddies come over and crack open few beers and we play online poker on this beautiful, huge display.
PC on TV is the future boys.
CP5670
5,668
768
Good luck...
The IBM T221 actually outdoes that in some sense (3840x2400 on a 22" screen, so pixel density is higher) and costs much less, around $8500. I have no idea what the image quality is like though.
ricleo2
1,122
11
Could you explain the details or supply a link for you HD tuner? Thanks.
Pneumothorax
1,181
23
Before you pull the trigger on any LCD Monitors... If you're planning on watching HD-DVD/Blu-ray on your expensive monitor, You might want to research the HDCP issue. None of the current 24 inch LCD's support it in their DVI inputs. so without an illegal "fix" you'll only be watching DVD's and regualr HDTV on these current models.
ricleo2
1,122
11
It's knowledge like this that makes this the best website. Thanks.
Toro 45
4,263
How long before HD-DVD/Blu-ray takes over and those types of monitors become "obsolete" for lack of a better term?
