What is the best AMD AIB partner for a 0db fan solution?
Elixer
10,371
762
For which card?
Usually, if you want 0db, then there is no fan at all, only a big heatsink.
Why 0db anyway? I doubt you will hear anything lower than 30db unless you happen to be in a dead silent room.
daperl
63
18
Well, I'm referring to stuff like Saphire's Intelligent Fan Control II, or MSI's ZeroFrozr. Things like that. And generally, if it's spinning, I can hear it.
3DVagabond
11,951
204
Are you wanting a passive card? Or just one that idles with the fan(s) off?
NM saw your reply. Generally Sapphire has the best cooling solutions for AMD. Personally I'd stay away from the AIB's who manufacture for both AMD and nVidia as they tend to use the same cooler for both brands instead of one that is specifically designed for the AMD card.
daperl
63
18
I want a card that will be silent when I'm not gaming, but will actively cool when needed. Massive heat sinks don't scare me; that's why I mentioned MSI. The idea of the fans being off while the GPU is < 60 degrees is enticing.
Elixer
10,371
762
Yeah, I agree, Sapphire is very good for AMD, all their coolers have been copied by other companies (even nvidia AIBs).
It also depends on which card you are looking at though.
Some cards, they will always have the fan running.
daperl
63
18
I'm gearing up for an RX 480, but I have no interest in a reference card. I think I'll download the SAPPHIRE TriXX Utility to see how versatile the fan profile stuff is. For my CPU and system I use SpeedFan and it gets the job done, but I have an EVGA GTX 760 and it doesn't support 0db functionality. Lame.
Headfoot
4,444
641
fan off in low load situations seems to be a popular new feature to add. You may see more AIB partners coming out with that kind of solution for the 480 in order to compete with those that already have. We'll find out in the next couple of weeks
