LG G2 is a very nice phone if you don't need the micro-sd slot. I used it for a few days and the phone is still very fast and has awesome battery life for a phone that came out 2 years ago. The bezel is very small for its screen size. I was tempted to sell my Oneplus One get a G2 instead because of its size.
If you can get one in the $150 range, i think it's a no brainer.
But if you're interested in the $200 Zenphone 2, there is currently a $25 off $200 promotion at Newegg with Visa checkout. Just get a filler item and $175ish for a zp2 is pretty good.
http://promotions.newegg.com/bts201..._mmc=AFC-C8Junction-_-cables-_-na-_-na&cm_sp=
I haven't seen the brand new G2 listings we saw 6x on slickdeals in forever. It's off my list of phones I recommend. Now the Zenfone 2 is the best deal to get.
with no 5.1.1 Lollipop and definitely no Android M, it's definitely getting a bit old. Additionally it has a multi-tap detection issue where sometimes it just averages the two taps. Bug in LG bloatware AFAICT.
Does anyone know of a site that rates reception on cell phones - since that is a major concern for me with using an off-brand carrier like MetroPCS.
Phonescoop is great as far as it goes but I need to find a place that does in depth reviews.
MetroPCS is T-Mobile MVNO now, FYI.
just got the asus zenfone 2 as a gift! cant believe how awesome a $200 phone can be. wow
slim phone with dual SIM slot, sd slot and even has wireless charging!! too bad its not waterproof though.
off topic. my metropcs sim card does not work in this phone. i also tried the sim on the s6 and that doesnt work. ouch
Yeah, 3FF seems to be the most common format for newer phones. Haven't seen any yet that use 4FFjust got the asus zenfone 2 as a gift! cant believe how awesome a $200 phone can be. wow
3FF was introduced in 2003, 4FF in 2012.Full-size SIM (1FF), mini-SIM (2FF), micro-SIM (3FF) and nano-SIM (4FF)
no reason it won't work. you did something wrong. change APNs
also: it does not have wireless charging
Very useful info there - thanks for posting that. I can't stand that sort of bullshit so I'm crossing Metro off my list. I'm guessing that leaves Virgin which sucks (based on my current and former phones' reception) and Cricket - or IOW Cricket.my metropcs sim is not working in the asus zenfone. i called metro, they said to use on a phone not purchased from metro, i would have to pay $45 per month. currently im paying only $30 unlimited everything with metro's free phone.
the asus back cover has a loop with 2 metal contacts, typical of the wireless charging module. are you sure asus doesnt have wireless charging? i dont have a wireless charging pad to test
Tonight my wife removed her Cricket SIM from her Moto G (Cricket) and inserted it into her new Moto G 3rd gen (non-Cricket purchased directly from Motorola.com) and I was concerned it wouldn't work immediately.
Worked just fine, no need to get a new SIM, de-activate, re-activate or contact customer service, it just worked. Call quality and LTE are fantastic.
Cricket = AT&T owned and operated prepaid
http://www.prepaidphonenews.com/2014/05/prepaid-operator-profile-cricket-gsm.html
Much appreciated gents. I was going to get a Cricket sim for my LG Volt but the Volt doesn't do GSM just CDMA. So I'm going to get an Idol 3 and then get a Cricket SIM. The fact that it seems to be a painless process to just plug their SIMs from one phone to another was main reason I made that decision. I'll report back in a week or so with results.ye, just tried a friend's cricket sim into my asus. just works fine. no tricks.
friend said he's paying $35 per month for unlimited everything. i might just do the $25 per month for only unlimited talk n txt, no data. no need for data since wifi hotspot are all over the city.
LG G2
Moto Gen3
Zen Phone
Can you rank from best to worst?
While the specs on a LG G2 are good, they'll lack all the LTE bands covered in the newer phones which will include things like Band 12 (700MHz) for TMobile, for instance.
someone corrected me once and I don't remember, but it has lower B,C bands (Band 17), of which Band 12 has lower A,B,C. The tower can differentiate and still use the B,C carriers.
But it might actually be G2 has upper B,C, and T-Mobile uses the lower A,B,C. I'd have to check.
IOW it should support it
additionally, there are still many areas where channel 51 has not been transitioned or shut off, which is interfering with deployment of T-Mobile's 700mhz in many markets.
