I have the s27a950d and I'm pretty sure the panels are the same on both the 750 and 950 models, just different inputs.
I have used the Samsung 2233RZ LCD as my main display since it was released, so I am quite familiar with it. The sa950 is a very good upgrade in my opinion and worth the money if you can afford it.
It feels like gaming on a smooth mini IMAX screen, you really feel like you are a part of the game with this monitor.
The 950 does everything better than my 2233RZ. Better colors, deeper blacks, faster response, bigger, better looking design and basically no heat from the display.
So that's what you can expect from the new 750 IMO, a really nice monitorHope this helps!
I wonder how it will compare to Samsung 2233RZ, the reference 120Hz monitor at TFT Central for responsiveness test. Then again, its still a TN panel and its hard to go back to TN from IPS/PVA.![]()
Whats up with the "All TN panels are POS" trend nowadays? Viewing angles are not something that's absolutely vital for a PC monitor. I have compared alot of monitors extensively. The Samsung S27A950D is a TN monitor but trust me the subjective IQ looks way better than any of Dells insanely popular e-IPS monitors. I have the 120Hz 2233RZ and IQ is decent as well.
I bought the A950 (27 inch that is) and am extremely happy with it. A few people have said the 750 has input lag and make sure you don't purchase the S model but the D.
For a bit more the 27 inch really makes things pop and with the slightly bigger pixels than a 23/24 inch monitor I find myself being able to see opponents in multiplayer I would have missed before.
Nvidia just announced 3D Vision II and much more responsive displays in this next gen. The new ASUS 27" is one of theseTN panels are POS. The colours are terrible and viewing angles are a further detriment to that issue. The only thing TN has going for it is response time.
And a large LOL to any TN looking as good as an IPS. They look awful, it's just something you get used to when it's all you use. The same way you get used to the quality of IPS when it's all you use. Any review of LCD monitors looking for IQ doesn't even include TNs, they're only relevant from a budget or response time perspective.
OP are you going to use this monitor for 3D ? If you're into that you should wait for these new-fangled 120hz monitors with this 'lightboost' rather than sink your money into the older tech ones on the market currently.
http://www.anandtech.com/show/4966/nvidia-announces-3d-vision-2-and-3d-lightboost-technology
If you're just buying now, might as well wait rather than buy old-tech.
You do realize that the A950 is awful right. You can't use it as a 120hz monitor in 2D, and it is slower than most 2ms TN panels.
The bezel thickness is the only real attractive part of the monitor, but it is ruined because it can't be VESA mounted. Giant waste of money for that monitor.
You know I read so much hype about IPS over TN that I bought a Dell U2311. Other than viewing angle from below it doesn't do any better than my previous LG W2442. In fact I actually prefer the colors on the W2442. Switched to the Samsung 2233rz and couldn't be happier with the gain in smoothness and clarity when gaming.
The A950 will do 120hz in 2d, same as the A750, but it only works over DisplayPort or Dual DVI cable (A750 actually only works over DP). The T-versions of these monitors are the gimped ones that will not to 120hz. Just make sure you get the S versions, S27A950D/S27A750D/S23A950D/S23A750D, all 4 of those will run 120hz in 2d no problem.
input lag and screen response time are two different things.I am under the impression that 120hz only works over DVI? Could be wrong though. Either way the monitor has enough input lag to make it comparable to a 5ms TN panel.
