What is the advantage of a flat screen tv (CRT not LCD) over non-flat?
GtPrOjEcTX
10,784
how is the light level in the room where it would be? flat is less reflection.
the view angle is also better.
also generally it has better picture as well.
vshah
19,003
24
sharper, less distortion, looks a heckova lot cooler....
but the first two are the big selling points...also, flat screens usually have higher quality tubes than non-flat...
edprush
2,541
I wonder why they ever built convex CRT screens...what technological advance allows for a flat screen in a CRT that wasn't around before?
CraigRT
31,440
I often wonder things like that... no friggin clue!
edprush
2,541
This MAY be the reason. Today's CCD cameras do not have the curved lens as earlier cameras had. Therefore the flat lens camera image is better reproduced on a flat screen....the thing is that I have no idea when this change took place.
Savij
4,233
I'm no expert but:
I thought it was because CRTs make a picture using a Cathod Ray Tube. The curved lense basically makes sure that the electrons travel the same distance from the electron gun to any point on the screen. This ensures that the distance between each pixel is the same throughout the screen. If you have a flat screen the distance between the pixels gets larger as you move towards the edges. A flat screen electron beam has to change its scanning speed as it goes across so that the picture doesn't appear distorted on a flat screen.
imported_KirbsAw
1,472
I'm no expert but:
makes sense to me
MDE
13,199
I'm no expert but:
Liar.
:D
Goosemaster
48,775
I'm no expert but:
Do flat screens would require stronger glass? Because Glass is brittle and you have a vacum inside, I would think that with a flat surface, all stress would be transfered to the center of the glass, unlike how concavity seems to allow for added strength and dispersion of energy.
slpaulson
4,414
14
I'm no expert but:
In my experience flat screens are heavier due to thicker glass.
Amused
57,114
18,644
I'm no expert but:
Yep, this is why the old Trinitron Sony TVs were always so much heavier. The glass was thicker.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Originally posted by: Qaabus
Flatscreens take longer to change the channel
No, that's purely a function of the tuner chip and has nothing to do with the picture tube design.
ZV
Goosemaster
48,775
I'm no expert but:
So I was right? Sweet. I wasn;t sure if I was making any sense
yhelothar
18,409
39
Cheap flat screens just use a flat glass, and will be far more distorted than a conventional non flat screen tv.
Unless the screen is a sony trinitron tube, I would not get flat screen.
Unless you have a lot of glare in your room, the curved glass should not be bothersome. Flatscreens are overrated IMO...
then again, check out my uber l337 dual 21" flatness
also all old tv's are heavy..
My old curved screen 21" manufactured in 1996 weighed 95lbs..
my new 21" FP Trinitron tube manufactured in 2003 weighs 65lbs
