What is System Idle Process and why is it taking so much resource?
LS21
Banned
Nov 27, 2007
3,745
i am looking at the task manager, and its taking up to 95% of my chip processor power. can i do a end process on it? is it a spyware software? (the last thing i put on my computer was itunes)
Special K
7,098
It's the "idle" process - it's not really doing anything. Basically any of the OS's time slices that don't get allocated to another process get used by the system idle process, which is probably just a loop of NOPs.
HN
8,186
4
that number for System Idle Process is not "taking up" CPU. it's actually how much cpu is "spare". watch your "CPU Usage" percentage at the bottom of task manager. as that goes up, the System Idle Process goes down. no worries.
Drako
10,697
161
Originally posted by: tasmanian
The only way to stop it is to delete system 32 in the windows folder.
LOL, I was going to suggest the same thing, but I'm not that mean :). BTW, it's probably easier to just delete pagefile.sys.
Feb 6, 2007
16,432
I pay all this money for a fast CPU and it's just sitting there IDLING? What a load of horseshit. It should be doing my taxes or some shit....
Narse
Moderator<br>Computer Help
Moderator
Mar 14, 2000
3,826
LOL I really really hope this is a joke thread!!
JulesMaximus
74,578
982
Originally posted by: FoBoT
hey, LS21, do you know what pickles are made of? i need some help figuring this out
That's easy, they are made of dill and the sweet ones are made of sweet.
mugs
48,920
46
I'm pretty sure this was a joke... the iTunes solidified it for me.
biostud
19,924
7,031
You've got a lazy CPU. It happens for 1 out of 1000 processors, because of a fault in production the metal is over stretched it needs to rest.
