What is signal to noise ratio?
shiznut123
Banned
Dec 22, 2000
2,954
On speakers specs it says signal to noise ratio 90db or something like that. What does it mean?
jj1492
241
The 90db you saw was probably the sensitivity. This means that the speaker will produce 90 decibels of sound given one watt of power.
Planktune
151
signal to noise is how much sound signal there is above the noise floor (background hiss and hum etc)
jamarno
1,035
Every 20 dB is a factor of 10, while every 10 dB is a factor of 3, and since dBs are the log theyse add. So 90 dB S/N means that the noise 10x10x10x3, or .003% as strong as the signal. Anything over 70-80 dB is inaudible, while 40 dB sounds like a cheap tape recorder, and 60 dB like a fairly good tape recorder with Dolby.
Workin'
5,309
And a good CD player will have an S/N of over 90 dB.... jamarno is correct in his explanation.
