What is road haze???
0roo0roo
64,795
84
its like a dirty fog on the inside of car windows. its not dust since its simply a haze, but how does it get there? air pollution? what gives?
Azraele
16,524
29
I've never had that problem. :confused:
Could it be light catching dust particles?
0roo0roo
64,795
84
no its not as bad as a total fog up. but if you get into your car and rub a finger against the window in light u'll notice that u wiped away a layer of dirt.
JC
5,848
68
I know what you're talking about. But I don't know what it is....
JC
that stupid thing comes from cheap interior waxes.. its the worst during hte summer. If you park in the sun with waxed dash exposed some of teh excess stuff evaporates.. and clings to the glass.
it icky i tell you.. just use decent glass cleaner (like amorall glass / windex and for the dash use a good dash protectant.. but I seldom use that stuff.
Originally posted by: 0roo0roo
interior wax? do dealers put that on your dash?
not sure if all dealers do but when they do an interior detail .. depending on the quality of the stuff things can vary. In general I use my own interior stuff and that reduces the stuff.. I use quality stuff on teh inside once every 3 months and that works great
0roo0roo
64,795
84
any examples? i've never heard of interior wax. only thing i've seen is armor all interior.
That's the stuff...
There are several types of interior stuff. Some expensive (retail) some that your local hand wash uses. My brother and I stopped using this one handwash because the stuff they used on the inside caused it on both our cars. These days we got another handwash place and they do the ouside and we bring it home and do the interior with our stuff.
0roo0roo
64,795
84
Originally posted by: HappyPuppy
It's gasified resin from too many doobies. Roll your windows down next time you fire up.
omg! my parents cars have it too:)
Yossarian
18,010
PVC is the plastic used for a lot of dashes. It has ingredients called plasticizers that allow it to be molded & processed easier (plus stuff for UV protection, color, etc.). The plasticizers migrate out of the resin when exposed to heat and light for long enough, that's what gets on your windshield. That's also why the dashes of old cars will crack easily, the plasticizer is mostly gone leaving just a brittle material.
