I am testing my ATI PowerColor X800XL. I want opinions on what should be a maximum load temperature for the card. I searched the forum, found only a 7900GT reference (my card runs hotter.) I could not find adequate reference on ATI/AMD site.
Catalyst CommandCenter is not installed, only the latest ATI "control panel" drivers.
I have "ATI Tool" running with no O/C, stock stettings, and the "3D Window" running for a 3D test. Window is about 3"X3", with a spinning fuzzy block for 3D effect.
For a temperature reading, I have ATI Tray running, as downloaded from Guru3D.com. Prime95 "blended test", cpuz, MBM, running in the background.
I get 73.5 degrees Centigrade on the "GPU temp", and 36 to 42C on the "GPU environment", which I assume is a board mounted sensor. Is this too high? Idle temps vary from 29C to 36C.
Reason that I ask is my son has games frequently crashing to desktop. I have run tests on processor and memory, and they pass all tests. (Prime95 and Memtest tests 5,6,8 and blended for ~ 20 hours each.) The games are memory intensive intensive (BF2, WOW, CSS) so that is where I started testing. He plays same games on two other PCs, same and different LANs with no problems. I don't think it is a firewall, system admin, or security issue.
Other web forum posts suggest that overheated video cards may cause crash-to-desktop. I don't have time to reproduce game crashes, and my son claims he sees no picture corruption before crashes. I haven't tried testing or logging while he plays.
Is 73C too hot for a X800XL? I would think the ATI Tool 3D test to be fairly mild.
I am not looking for ways to cool the card down, that I can figure out if it needs to be done. What I need are parameters for cooling limits.
Thanks!!
Thanks!!
